search the site
Go Back   SkyscraperCity > Infrastructure and Mobility Forums > General Developments and Discussions > Bridges
Old January 14th, 2015, 05:51 PM   #21
[atomic]
Likes (Received): 116
if I understand right the issue is free access to the Sea of azov which is an inland Sea of 2 countries and if someone wants to limit access to it both countries have to agree to it.
[atomic] está en línea ahora   Reply With Quote
Old January 15th, 2015, 10:27 AM   #22
Aokromes
Patatero Inside
Aokromes's Avatar
Likes (Received): 2345
Maybe then they can make one small underwater section.
Si quieres compatibilidad con estandares y seguridad, ¿pq recomiendas Firefox y no Opera?
If you want compatibility with standards and security, ¿why do you recomend firefox and not Opera?
The only truly secure system is one that is powered off, cast in a block of concrete and sealed in a lead-lined room with armed guards - and even then I have my doubts. Gene Spafford.
I am Basque, not Russian, the "Siberia" thing is a joke.
Aokromes no está en línea   Reply With Quote
Old January 15th, 2015, 05:32 PM   #23
Woonsocket54
PC LOAD LETTER
Woonsocket54's Avatar
Likes (Received): 4626
A funicular is now also proposed.
http://ria.ru/crimea_today/20141217/1038785489.html
One commenter on the article predicts that the Kerch Strait Catapult will be the next proposal.
Zaz965, Kozhedub, adevahi liked this post
Woonsocket54 no está en línea   Reply With Quote
Old January 30th, 2015, 02:45 PM   #24
Avangard-55
Avangard-55's Avatar
Likes (Received): 3508
http://www.handelsblatt.com/unterneh.../11304842.html
According to this article, the company Stroygazmontazh of Arkady Rotenberg will shall build the bridge till december 2018.
Avangard-55 no está en línea   Reply With Quote
Old January 30th, 2015, 05:58 PM   #25
Woonsocket54
PC LOAD LETTER
Correct. He is a friend of the most polite president.
http://ria.ru/infografika/20141031/1031185843.html
Zaz965 liked this post
Old January 30th, 2015, 09:28 PM   #26
Highcliff
Fake democracy
Likes (Received): 5010
more one pic...
http://www.tol.org/client/article/24...t-honored.html
Highcliff no está en línea   Reply With Quote
Old February 26th, 2015, 08:12 AM   #27
Woonsocket54
PC LOAD LETTER
This is becoming redundant now that Russian occupation of Mariupol is looking more certain by the day.
Old April 7th, 2015, 08:07 PM   #28
SDrake
With all the unrest in the area, I doubt there would be money to invest to build it. Russia is very tight economically at the moment.
SDrake no está en línea   Reply With Quote
Old April 8th, 2015, 07:18 AM   #29
moosefoot
Likes (Received): 491
Highly doubt it. Besides, Mariupol is a long way from the closest land bridge to Crimea:
The kind of massive military endeavour implied here (securing a passage 200-250 miles into foreign territory, taking control of rail infrastructure etc) would be immensely expensive both economically and diplomatically.
I bet the bridge across the narrow little strait (3 miles of water only a few feet deep, save for the central channel that allows ships to pass through) would wind up being way cheaper than that, not to mention just beefing up shipping (which is already happening).
There is no unrest in the Republic of Crimea or in Krasnodar Krai, the two territories that are relevant here. I don't know how the financing situation looks like, but I suspect this thing's gonna be delayed a lot even though construction is said to start in a few months...
Foreign investment is probably out of the question for obvious reasons and while Russia does afford it on its own even at this stage, it's not like there aren't other areas that need big spending much more.
Also, the money already allocated for bringing Crimea up to Russian standards (fixing the crumbling infrastructure, communications etc) and making it independent from Ukraine in terms of water supply etc is ridiculous as it is (just look in the Russian section here on this forum, there are a number of Crimea threads kept up to date by residents of the peninsula, the amount of stuff being done is nothing short of staggering ). Even bigger money might become difficult to justify down the road, since a lot has to be done elsewhere too.
Well, I'll be watching it but I'd wager that the proposed timetables are a wee bit too optimistic...
moosefoot no está en línea   Reply With Quote
Old April 8th, 2015, 08:33 AM   #30
moosefoot
Actually, come think about it... The "Tuzla" version of the bridge that seems to be what they're going for now (that uses Tuzla Island for a portion of it) could perhaps be built in 2-3 years. Now, I'm only a layperson and I might be horribly wrong but this is how I see it:
Apart from the fact that almost 1/3rd of the way is across said island, the water depth is nearly negligible over the remaining 2/3rds (hovering around 3 feet most of the time, apart from the aforementioned channel just off the coast to the west that is very narrow and the only portion that would require a "proper" bridge to facilitate for passing ships). That ought to make things a fair bit easier, seeing that a person of average height could actually wade beside it most of the way...
A somewhat similar bridge (across shallow water, considerable length, no huge free spans) was built north of Vladivostok in the Russian Far East a few years ago, namely the motor bridge across the Amur bay. It's of similar length and was built in less than 3 years:
https://ru.wikipedia.org/wiki/Мост_через_Амурский_залив
(no English article on it I'm afraid)
However, it is only a motor bridge so I guess flinging a railway on it as well (as they're proposing in the Kerch case) would make construction take longer and naturally be way more expensive.
Another similar thing that's U/C is the so-called "Western Rapid Diameter" in St. Petersburg - a massive highway along the western waterfront of the city. Only parts of it are across water (the mouths of the Neva river "delta"), but nearly all of it is elevated. There are some threads about it in the Russian section, like this one:
http://www.skyscrapercity.com/showth...731398&page=62
Interestingly, one of the companies that are involved in this ongoing St. Petersburg project are also involved with the Kerch strait bridge project. This company was also involved in Vladivostok, but not with the Amur bay bridge, just the massive and indeed well-known "Russky" bridge.
So based on this, I think that it actually can happen (re Kerch, that is) reasonably fast, if the money's there. These folks have gotten things done in the past and know what they're doing. Now, they also seem to be saying that money is indeed available:
http://www.c-inform.info/news/id/21330
(article from yesterday in a Crimean news outlet)
And all the preparations are supposed to be done by August, with construction commencing shortly thereafter... Interesting.
Old April 9th, 2015, 12:33 AM   #31
moosefoot
Another serious issue reported here:
http://ankerch-crimea.ru/page/news/71299/
The area is littered with UXO left from World War II, and they have already found and defused several bombs.
Old April 14th, 2015, 04:09 AM   #32
TEBC
TEBC's Avatar
Likes (Received): 5248
any news?
rio 20!6
Viva essa Paixão
TEBC no está en línea   Reply With Quote
Old April 16th, 2015, 10:22 AM   #33
moosefoot
Originally Posted by TEBC View Post
any news?
Work is apparently ongoing.
Now, construction equipment is starting to show up on the Taman pensinaula:
Zaz965, DJaCoNdA, DEsl, brick84, Qtya and 4 others liked this post
Old May 21st, 2015, 07:30 AM   #34
Woonsocket54
PC LOAD LETTER
Photos have been posted to facebook showing construction of the bridge
https://www.facebook.com/MySimf/posts/543974855741482
Gubot liked this post
Old May 21st, 2015, 01:58 PM   #35
DEsl
Likes (Received): 345
Can we pls stick to the bridge and not the Ukrainian war?
DEsl no está en línea   Reply With Quote
Old May 28th, 2015, 10:06 PM   #36
Woonsocket54
PC LOAD LETTER
sucks that you were brigged. Hope it's not for long.
Old May 28th, 2015, 10:52 PM   #37
void0
Likes (Received): 2838
Bridge construction is the matter of surviving of the Crimean residents, because from time to time (depends on commercial interests of the Ukrainian companies, delivering good to Crimea) Ukraine closes the borders. This is also applied to construction of energy bridge to Crimea, because now Ukraine supplies Crimea with the electricity just because Russia does it to Ukraine by very discounted prices.
I hope they will use Crimean subcontractors as much as possible, because currently wages in Crimea are only 50% of Russia's average and this should be improved.
I think the bridge will be completed according to schedule, that is autumn 2018.
void0 no está en línea   Reply With Quote
Old June 3rd, 2015, 12:24 PM   #38
DEsl
I doubt it will go 100% according to schedule but when it is completed it will will increase the living standards of many Crimeans
Avangard-55 liked this post
Old June 23rd, 2015, 08:59 AM   #39
moosefoot
Lots of activity now, and the temporary bridge to the central island is well underway:
Workers barracks:
Highway construction/extensions in both Kerch and Taman (M25/A290/E97) are also underway. The bridge will link them up (previously M25 terminated at Port Kavkaz).
Old July 16th, 2015, 01:42 PM   #40
Avangard-55
Originally Posted by megajack View Post
с роадс.ру, панорама Тузлы:
(кликабельно)
It's going on.
Wir sind die Niedersachsen, Sturmfest und erdverwachsen, Heil Herzog Widukinds Stamm!
DEsl, Zaz965, nvtimports, bus driver, Qtya and 1 others liked this post
