Go Back   SkyscraperCity > Asian Forums > Philippine Forums > Projects and Construction > Metro Manila Projects on the Rise > Completed Projects
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
Old September 11th, 2010, 12:28 PM   #1
derf
derf's Avatar
Likes (Received): 117
MANILA | Wharton Parksuites [39F|154m|res]
Project brief: To cope with the sustained demand for high quality and luxurious condominiums in Manila, Anchor Land is developing another 39-storey tower in Binondo, the Wharton ParkSuites, along Masangkay Street. The project is targeted towards transients and travelers who frequent Chinatown to do business, or those who send their children to the distinguished Chinese schools in the district.
The unit designs of Wharton Suites reflect the functionality of a luxury hotel and the convenience of modern amenities and learning facilities like wi-fi internet, a well-appointed library, fast food areas, and other standard features like a gym, and hobby room to keep the resident's mind and body always in tiptop shape. Tutorial facilities, activity and recreation centers are also added to provide a perfect venue for learning and creative recreation.
PROPERTY AND STRUCTURE DIMENSIONS
The property is located at La Torre St., cor. Masangkay St., Sta. Cruz, Manila
The total lot area is 1,152.60 square meters.
Building footprint is 715.08 square meters.
The total gross floor area of the project is approximately 39.498.10 square meters.
The building is composed of 39 levels with roof deck and machine room deck for elevator. It has a total height of 154.15 meters approximately from ground level up to the apex of the crown. Numbering of floors is up to 39th level excluding 13th level.
There will be one (1) main lobby located at the ground floor.
The lobby will have a vertical height of 5.20 meters.
Total area of the lobby including reception, lounge and elevator lobby is 159.83 square meters.
Four high speed elevators will be provided (3-15 passenger elevators, 1-20 person service elevator)
RESIDENTIAL UNITS
The floors that will be covered by residential units will be from 8th floor up to the 39th floor.
The floor to floor height of each residential unit is 3.25 m. (One of the highest in the industry)
Material to be used for the interior of the residential units:
Floor
Living & Dining : 600mm x 600mm homogenous tiles
Kitchen : 300mm x 300mm ceramic tiles
Bedrooms : Laminated floor finish
Toilet : 300mm x 300mm unglazed ceramic tiles with waterproofing
Walls
Unit Partitions : 6” thick CHB walls, latex semi gloss enamel paint finish
Interior Partitions : 4” thick CHB walls, latex semi gloss enamel paint finish
Toilet : 300mm x 300mm ceramic wall tiles
Ceiling
Living, Dining, Kitchen: Poured concrete off-form skim coated painted finish
Windows:
Tempered glass on aluminum powder coated frame
Doors
Main Door : Wooden Panel door
Bedroom doors : Hollow core flush door
Toilet & Bath doors: Wood Door
Maid’s Room : PVC Accordion Door
Cabinets : MFC cabinets
STRUCTURAL SPECIFICATION AND UTILITIES
The building will use combination of Bored piling and matte footing works.
All residential units have electrical provision for split type air-conditioning unit for living/ dining, and bedrooms. Space for condensing units is also provided.
Electrical provision would be provided for water heater. Single point Water heater to supply shower heads will be provided by the unit owner.
Water tanks will be provided at roofdeck. Cistern with 75,000 U.S. gals., and fire reserve tank with 60,000 U.S. gals. will be located below Ground level.
In the event of normal power failure, generator sets will be utilized as standby power source of the building. The common areas will have 100% back-up power while each residential unit will be provided with a limited power enough to run basic appliances and light. The emergency power will be diesel-fueled engine generator sets.
Can the genset provide enough power for the entire building?
The following percentage will be provided by the genset:
a. 100% lighting and receptacle outlet for common area.
b. 100% life safety and essential load.
c. 30% lighting and receptacle load for commercial area.
d. For residential, 1 receptacle for refrigerator, 1 for living area and 1 for master’s bedroom.
All residential units will be provided with individual electrical sub-metering. Emergency power consumption will be billed on a pro-rated basis. No metering for emergency power.
Individual water meters are also provided for each unit.
AMENITIES, SERVICES AND OTHER FEATURES
• Adult lap pool (25.00 x 5.00 meters)
• Kiddie pool
• Taichi area
• Exercise area / zone
• Kiddie corner with rubber mat flooring
• Function room for parties, birthdays, corporate events, meetings, family gatherings, etc)
• High ceiling amenity lounge with soothing hard and softscape
• Music corner for violin, piano, guitar, and drum
• Library provided with reading area/ Internet corner / Wi-fi zone
• Tutorial rooms
• Chess corner
• Conversation nooks
• Jogging path
• He/ She shower rooms
• Water features
• Viewing decks
• Rock gardens
• Naturally ventilated yoga room
• Meditation area
• Fitness center overlooking the pool
What are the other features of the project?
a. 24-hr security.
b. 7 levels of parking
c. 4 high speed elevators
d. Automatic fire alarm and sprinkler system
e. CCTV
f. Natural ventilation at lift lobby
Safety features of the building:
a. Building life safety compliance to local fire code and NFPA 101 safety code.
b. Semi-addressable Fire Detection and Alarm System.
c. Automatic Fire Sprinkler System (AFSS)
d. Two fire escape locations at all levels.
e. All equipment provided with accessible clearance for maintenance.
f. Fire rated residential doors
g. Security intercom
derf no está en línea   Reply With Quote
Old September 13th, 2010, 07:43 AM   #2
acerkraig
Contractor Investor
acerkraig's Avatar
this project is Developed by Manila Towers dev't. Corp, was designed by Albert S. Yu Architects, and Construction is Managed by Prompt Managers and Construction Services Inc.
Not quite familiar with the CM and the Developer. The architect is one of architects used by SM to do the SM Residences and Sm City projects.
acerkraig no está en línea   Reply With Quote
Old September 13th, 2010, 07:44 AM   #3
acerkraig
Contractor Investor
acerkraig's Avatar
I wonder when is the completion of this project,, and what is the update? is it already under construction?
Old October 9th, 2010, 02:04 PM   #4
ruffarambo1
ruffarambo1's Avatar
ruffarambo1 no está en línea   Reply With Quote
Old October 9th, 2010, 02:12 PM   #5
ruffarambo1
-dp-
Old October 10th, 2010, 04:10 AM   #6
zandro888
Ganda ng renders, i just hope they will follow thru on the construction
zandro888 no está en línea   Reply With Quote
Old November 1st, 2010, 04:46 AM   #7
badsector
any updates about this?
badsector no está en línea   Reply With Quote
Old November 1st, 2010, 08:00 AM   #8
Bosnyboy
Likes (Received): 2386
Already under construction.
Bosnyboy no está en línea   Reply With Quote
Old December 3rd, 2010, 04:27 AM   #9
alanhunter169
When's the expected completion date for this?
Find the best
has to offer. Check out
now.
alanhunter169 no está en línea   Reply With Quote
Old December 3rd, 2010, 08:46 AM   #10
derf
derf's Avatar
December 2012 plus an allowance of 6 months..
Old December 8th, 2010, 05:45 AM   #11
derf
derf's Avatar
Pic taken december 7, 2010..
Old December 9th, 2010, 12:35 PM   #12
joker0153
Likes (Received): 48
Ok, I live near that site, I can take pictures every now and then. This is a good start in modernizing the metro.
joker0153 no está en línea   Reply With Quote
Old December 31st, 2010, 11:24 AM   #13
derf
derf's Avatar
Wharton scale model in the showroom
Old December 31st, 2010, 11:09 PM   #14
saintm
Beautiful User
saintm's Avatar
Likes (Received): 569
ang ganda!
saintm no está en línea   Reply With Quote
Old January 28th, 2011, 03:35 AM   #15
derf
derf's Avatar
Anchor Land bares 7 new projects this year
MANILA, Philippines - Placing its bet in on a resurgent property market, listed high-end Binondo-based developer Anchor Land Holdings Inc. is gearing up to launch seven new projects – from commercial developments to luxury residential suites – this year.
“This is our vote of confidence on the Philippine economy in general and the property sector in particular. It is also our way of living up to our motto of 100 percent commitment to deliver all projects on time, without sacrificing the quality and beauty of our developments,” said Anchor Land chairman Stephen Lee Keng.
Another bestseller is the 39-story Wharton Parksuites, which caters to those who send their children to the most prominent Chinese schools in Binondo. The project is likewise nearly sold out.
http://www.philstar.com/Article.aspx...bCategoryId=66
Old February 2nd, 2011, 04:48 PM   #16
anzen
anzen no está en línea   Reply With Quote
Old May 11th, 2011, 03:37 AM   #17
derf
derf's Avatar
As of May 2, 2011..
Old May 11th, 2011, 01:26 PM   #18
leroy366
WHERE IS THIS BUILDING???
As of May 2, 2011..
WHERE IS THIS BUILDING? AYALA AVE.???
leroy366 no está en línea   Reply With Quote
Old May 11th, 2011, 04:42 PM   #19
derf
derf's Avatar
Masangkay street near all those chinese schools, st. stephen, chiang kai shek, hope christian, sakya, uno, phil cultural.. Thats why this is one of the fastest selling projects in the philippines and is nearly sold out as investors are trying to cash in on the influx of mainlander chinese and the expansion of all these schools. That is unfortunate for other investors who are only keen on the makati and fort boni areas, not knowing that there are opportunities elsewhere.
Old May 11th, 2011, 09:58 PM   #20
ej101%
[QUOTE=derf;77556805]As of May 2, 2011..
Thanks Derf for uploading latest pics ... sana matapos ng Dec 2012 ! =)
Maaga ba mag-turnover ang Anchor Holdings , based on previous history ?
ej101% no está en línea   Reply With Quote
manila
Rate This Thread
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
Feedback Buttons provided by Advanced Post Thanks / Like (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
