Gwalior Airport (IATA: GWL, ICAO: VIGR) is a civil enclave airport at the Maharajpur Air Force Station 10 km (6 mi) north-east of Gwalior, Madhya Pradesh, India. It is one of the six airports in Madhya Pradesh and fourth Largest Airport in Madhya Pradesh. The airport is spread over an area of 760 acres (310 hectares). The airport is spread over 760.7 acres (307.8 hectares) and has a single terminal ie. Rajmata Vijaya Raje Scindia Terminal and can handle 350 passengers per hour. The 100m X 150m apron can handle one Airbus A320 and one small aircraft simultaneously. The Gwalior Air Base is the only operational air force base with two operational parallel runways. The second runway was built in February 2009 and became operational in October 2010.
Currently the civil enclave is in dire need of expansion. Two options are being looked over one is building a new integrated terminal by acquiring land from the nearby Potato Research Institute whereas the other one is to build a completely new greenfield airport for Gwalior. Alliance Air, SpiceJet and IndiGo connect Gwalior to most major cities in India.
